Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
In flight adjustment using VR knobs
Old 05-18-2010 | 01:24 PM
Default In flight adjustment using VR knobs
Hi there,
I have purchased a Futaba 10c set and have set up my glider on it using Glid 1ail+1flp. I have defined a mixer to apply elevator when deploying air brakes which are on ch3 with ch2 being the slave. The mixer is on all the time.
What I want to do is adjust the rate in flight to trim the model out, can this adjustment (rate) be allocated to a VR knob so it can be turned in flight ???
Thanks<br type="_moz" />
Old 05-18-2010 | 01:47 PM
Bax
Default RE: In flight adjustment using VR knobs
Basically, you want a way to change the percentage of mix "on the fly". Unfortunately, the 10C doesn't have that provision in the mixers. What you want to do is use a point mix and then define the points of mix you need...it will take several flights and a bit of "try and see" to get the mix ratios correct.
