RCU Forums - View Single Post - Low speed needle setup on gst 7.7........
Old 05-18-2010 | 02:52 PM
nomobux's Avatar
nomobux
Default RE: Low speed needle setup on gst 7.7........
I'm wondering if you damaged the screw. You should be opening the throttle before you screw it in. Pull the air filter and look down the carb, open the throttle a bit and adjust in and see what happens. You may have worn the tip down or something.
