RE: changing transmitters
Or, before you switch transmitters, remove all the electronic trims by making manual linkage adjustments . . . which you should do anyway. When I get bored in February I cancel out all my sub-trim settings by doing it "the old way" and adjusting the linkages in order to zero the sub-trims.
