RCU Forums - View Single Post - Construction of a 2x2 pattern plane: the ANTI-GRAVITON
Old 05-22-2010 | 04:11 AM
geoffroyBelgium
Default RE: Construction of a 2x2 pattern plane: the ANTI-GRAVITON
I do not realy save a lot of weight by choosing 6mm Depron rib instead of balsa. It will be possible to save weight with 3mm depron. However, Depron is very easy to cut and very cheap if we compare with balsa. In addition, I don't know if it's the same all over the world but in Belgium, it becomes very difficult to buy good quality Balsa. Then, when it's possible, I replace the balsa by alternative solutions.
