RCU Forums - View Single Post - Nitro or 8e series Diff units Breaking Teeth off Ring Gear???
Old 05-22-2010 | 06:36 AM
formula87's Avatar
formula87
Default RE: Nitro or 8e series Diff units Breaking Teeth off Ring Gear???
Well I just pulled everything down again after reshimming pinions front and rear.  rear gears looks okay maybe starting to chip teeth but front missing two teeth........!!!! may be from over shimming.     Well I moved the diff with the ring gear back and forth and it has play in the case so I will be shimming that for the side to side movement and takeing some shimms out of the pinion.  I will post a vid on this and see what you think.
