RE: Sunstorm 600 need help
Unauthorised turns and throttle suggest a problem with radio gear. Try a range check. Then swap out different radio components (rec, servo) and try again. If you think its esc, then swap that out and test again. I know its hard to do if you're new to this hobby because of a lack of parts and extra gear that long time boaters have accumulated. You can also ask for help at the shop you bought it from.
