RCU Forums - View Single Post - Construction of a 2x2 pattern plane: the ANTI-GRAVITON
Old 05-23-2010 | 06:07 AM
geoffroyBelgium
Default RE: Construction of a 2x2 pattern plane: the ANTI-GRAVITON
Then, I continue to post some pictures
The stab, the rudder and the small vertical wings are finished!
The longerons of the wing are reinforced with carbon, epoxy and a thin hard wood.
The trailing edges are also reinforced
Now it's time to start the construction of the fuse!
The motor, the controller and the Lipos come from china. I know that the small turnigy motors are very good if consider the price. I will test this big one.
The fuse will be constructed from 6mm depron formers.
