RCU Forums - View Single Post - starting?
Thread: starting?
Old 05-24-2010 | 09:09 AM
dakotanut
Default RE: starting?
Check the glow plug and the carb settings. Make sure you have fuel in the lines. Make very sure that the glow plug igniter is well charged. The manual I have for mine was wrong on the HSN and LSN. I'm not sure what you have so I can't tell you if it is the same or not. Check the trim on the radio also. Good luck!
