RCU Forums - View Single Post - Kit or RTF????
Old 05-24-2010 | 02:45 PM
Solman
Default RE: Kit or RTF????
<span style="font-family: arial; ">Collective Pitch like the blade msr. Most hobby shops will test fly one for you to see. Let us know what you end up with and good luck on your hunt.</span>
<div></div><div>Wrong answer, the MSR is a fixed pitch heli.</div><div></div><div>[quote] <span style="font-family: arial; ">Since people here seem obliged to correct me, I will go somehwere else where my knowledge is accpeted without personal attacks.[<span style="font-family: Arial; ">/quote]</span></span></div><div></div><div>Bye bye. BTW, wasn't trying to personally attack you. Just saying that you came across disrespectful.</div><div></div><div>
<span style="font-family: arial; ">CP is collective pitch. The blade speed stays pretty much the same and to go higher you just increase the pitch of the blades.<span style="font-family: Arial; ">
</span></span></div><div></div><div>You did good explaining, but your a bit off. CP has the same throttle range, but you can program pitch curve and throttle curve depending on what you want. So basically as you increase your throttle, your pitch is changing with your throttle. When you are in 3D mode, your throttle stays really high and changes very little. 3D mode is more based on your pitch than your throttle and you typically have +/- 12 degrees of pitch. It is very difficult to pull off any aerobatics with a fixed pitch heli. Here is a cool video of what you can't do with a fixed pitch.</div><div></div>[youtube]http://www.youtube.com/watch?v=l08sONIYaFs[/youtube]<div></div>
