RCU Forums - View Single Post - Been quiet on the ole conversion board..
Old 05-25-2010 | 01:05 PM
  #43
av8tor1977's Avatar
av8tor1977
Default RE: Been quiet on the ole conversion board..
Use a carb with an 11mm venturi. The Zama carbs fit the Super Tiger .90 conversion a bit better than the Walbros because they are a bit smaller physically, but a Walbro will fit. You might have to grind down one of the regulator cover screws. The regulator cover should go towards the engine, not towards the prop.
AV8TOR
