Gerry,
Try to fly at Markham Park without AMA membership and you will be denied entry. Try to fly anyway and the park rangers will ask you to leave. Continue to fly and you will get arrested for trespassing. You will also be escorted off the field used by the PBRCA (a public county park) if you try to fly without AMA membership by the Sheriff's Department. The Bush Pilot's field is also the same way. The county REQUIRES AMA membership to use the facility...period.
What exactly did you ask the AMA?
Beave
ORIGINAL: gjhinshaw
I thought so too. So I called AMA and talked to Todd..... He said I was right.. Call AMA... 1-800-I-FLY-AMA
