RCU Forums - View Single Post - DX6i, Trim?
Thread: DX6i, Trim?
Old 05-27-2010 | 12:22 AM
jon6565's Avatar
jon6565
Default RE: DX6i, Trim?
ORIGINAL: tecboy
I have E-flite Blade 400 with DX6i. I'm talking about the pitch angles setup correctly. I assume that throttle trim has to be in the middle to zero the pitch angle, and the throttle stick down and up has to be -10 and +10. Is this correct?
That is correct but you will need to be in idle up (F. Mode 1) with the motor disconnected (any two leads) or in HOLD. This is to make sure you get full + and full - pitch range.
