RE: Custom Piston Rings
Frank, I will call you tomorrow. The bore is 36 MM & I can measure the ring thickness with a micometer with standaed mike. I also have a mike for piston rings. It measures form face inside of ring. The anvel is round. But it looks like I may need to send you the piston & ring. Thanks Capt,n Note in photo...not to much contact surface to measure!!!!
