RCU Forums - View Single Post - This is Bad Right?
Old 05-29-2010 | 07:36 PM
Tired Old Man
Default RE: This is Bad Right?
140 rpm could easily be written off to atmospheric "noise". If you have higher baro pressure than your last tach run you could pick up that much rpm doing nothing. Don't want to dissapoint, but don't want your sights too high either. See what happens in an hour or two of running after the rings and clean up.
