<div>Short answer, NO.</div><div>
</div><div>
</div><div>
</div><div>Long answer. . .</div><div>
</div>LifePo packs are allot more durable and robust. They can take a beating and be rapid charged.<div>
</div><div>LiPo's can easily be over heated and blow up if not charged properly. They also can not be run down below 3.0 V per cell (most people stop running when they hit 3.3v/cell) or they suffer damage and will loose charge capacity dramatically.</div><div>
</div><div>Lipo's have more a better power to weight ratio, but only last about 1000 cycles and take about 1 hour to charge. LifePo's have slightly higher power to weight ratio, but last allot longer and can be charged (with the appropriate charger) in about 15 minutes. (pack size dependent)</div><div>
</div><div>here are some quick stats from the powerfull wikipedia;</div><div>
</div><div>LifePO;</div><div><span style="font-family: sans-serif; font-size: 13px; line-height: 19px; "><table style="font-size: 11px; color: black; background-color: rgb(249, 249, 249); border-top-width: 1px; border-right-width: 1px; border-bottom-width: 1px; border-left-width: 1px; border-top-style: solid; border-right-style: solid; border-bottom-style: solid; border-left-style: solid; border-top-color: rgb(170, 170, 170); border-right-color: rgb(170, 170, 170); border-bottom-color: rgb(170, 170, 170); border-left-color: rgb(170, 170, 170); margin-top: 0.5em; margin-right: 0px; margin-bottom: 0.5em; margin-left: 1em; padding-top: 0.2em; padding-right: 0.2em; padding-bottom: 0.2em; padding-left: 0.2em; clear: right; width: 22em; text-align: left; line-height: 1.5em; " cellspacing="5" class="infobox"><tr><th style="vertical-align: top; text-align: left; ">Time durability</th><td style="vertical-align: top; ">>10 years</td></tr><tr><th style="vertical-align: top; text-align: left; ">Cycle durability</th><td style="vertical-align: top; ">2,000
cycles</td></tr><tr><th style="vertical-align: top; text-align: left; ">Nominal cell voltage</th><td style="vertical-align: top; ">3.3
V</td></tr></table>and LiPo;</span></div><div><font size="3" face="sans-serif"><span style="font-size: 13px; line-height: 19px;"><table style="font-size: 11px; color: black; background-color: rgb(249, 249, 249); border-top-width: 1px; border-right-width: 1px; border-bottom-width: 1px; border-left-width: 1px; border-top-style: solid; border-right-style: solid; border-bottom-style: solid; border-left-style: solid; border-top-color: rgb(170, 170, 170); border-right-color: rgb(170, 170, 170); border-bottom-color: rgb(170, 170, 170); border-left-color: rgb(170, 170, 170); margin-top: 0.5em; margin-right: 0px; margin-bottom: 0.5em; margin-left: 1em; padding-top: 0.2em; padding-right: 0.2em; padding-bottom: 0.2em; padding-left: 0.2em; clear: right; width: 22em; text-align: left; line-height: 1.5em; " cellspacing="5" class="infobox"><tr><th style="vertical-align: top; text-align: left; ">Time durability</th><td style="vertical-align: top; ">24–36
months</td></tr><tr><th style="vertical-align: top; text-align: left; ">Cycle durability</th><td style="vertical-align: top; ">>1000
cycles</td></tr><tr><th style="vertical-align: top; text-align: left; ">Nominal cell voltage</th><td style="vertical-align: top; ">3.7 </td></tr></table>
</span></font></div><div><font size="3" face="sans-serif"><span style="font-size: 13px; line-height: 19px;">So, to answer your question. No you don't have to do anything. Just don't run them down to low or they will break.</span></font></div>
