ORIGINAL: robbiesmechanic
i just bought a new ofna ultra lx1. the break in process went great, then the next day when i went to run the buggy it freaked out. when i started it up it went full throttle, i checked everything. the remote was on and everything was working. then i fired it up again and it done the same thing. i adjusted the trim on the remote and it was fine. then i run it for a couple of minutes made one jump the it went nuts. finally died then i checked everything again. i fired it up again run a min or so made one jump and BAM full throttle for no reason. it barely wants to turn and it will not turn if sitting still. i have changed the steering servo 3 times. could it be this cheap AM radio that comes with it? did i mention that i had my lhs pro look at it.. everything looks fine, no metal to metal. but both servos twitch (sometimes)..... please help me!!!!!
Do you live or were you near some place that would be using an A.M. system?
