RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
HELP PLEASE
Old 05-29-2010 | 09:17 PM
Default HELP PLEASE
i just bought a new ofna ultra lx1. the break in process went great, then the next day when i went to run the buggy it freaked out. when i started it up it went full throttle, i checked everything. the remote was on and everything was working. then i fired it up again and it done the same thing. i adjusted the trim on the remote and it was fine. then i run it for a couple of minutes made one jump the it went nuts. finally died then i checked everything again. i fired it up again run a min or so made one jump and BAM full throttle for no reason. it barely wants to turn and it will not turn if sitting still. i have changed the steering servo 3 times. could it be this cheap AM radio that comes with it? did i mention that i had my lhs pro look at it.. everything looks fine, no metal to metal. but both servos twitch (sometimes)..... please help me!!!!!
Old 05-29-2010 | 09:41 PM
Default RE: HELP PLEASE
ORIGINAL: robbiesmechanic
Do you live or were you near some place that would be using an A.M. system?
Old 05-29-2010 | 10:13 PM
Did you recharge the rx battery? If using Alkalines they don't last long.
Old 05-29-2010 | 10:19 PM
it does it at the track and the house... it give me no problems the first day and the next nothing but problems. i put new batteries in the remote and the receiver and the problem was still there.
Old 05-29-2010 | 11:03 PM
Where did'nt it give you problems? Try it therre and see what happens... Might wanna try to switch crystals...
Old 05-29-2010 | 11:09 PM
ORIGINAL: dug44
i know at the track i frequent (rcmadness) there is usually anywhere from 50-100 racers... It's hard, tons of interference... dsm system is usually a must.
Old 05-30-2010 | 01:22 AM
tommygun32's Avatar
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
robbiesmechanic, I don't know the Ultra LX1, but I'm guessing it's like most other sort of buggy. Sounds to me like you may have a stripped out throttle servo horn insert.
Most servo horns don't fit directly onto the servo post. There will be a small plastic insert you place inside the horn, that couples with the servo post. There is usually a letter on these inserts that corresponds with the servo maker. I.e: F = Futaba, H = Hitech, etc.
Or upgrade to an aluminium servo horn made to fit the servo brand.
Give that a try and let us know.
Old 05-30-2010 | 10:08 AM
its not just the throttle servo............... its both servos....... run great first day and then i replaced the steering servo on the second day and they are both acting up now. it doesnt matter if im at the track or the desert........ it does it anywhere.... im use a friends receiver and radio and see if that fixes the problem
Old 05-30-2010 | 12:02 PM
tommygun32's Avatar
Sounds like a good idea. Try a FM or Spektrum system. If it clears up, you'll know it's a problem with your AM system.
Old 05-30-2010 | 12:19 PM
Also, be sure to check all wires for nicks or breaks.
Old 05-30-2010 | 02:12 PM
check to make sure that the reciever cable(ANTENA) is not to close to the engine as that will also produce radio interfierence. Are your batteries O.K. NON leaking or not charging properly.
Keep us informed so we can follow and help out a bit, then when your ready get ready to race.
Old 05-30-2010 | 09:48 PM
so i replace the steering servo again cause there was bare wire showing and i think that was part of the problem... i also switched to a traxxas 2.4 system and all the problems went away....so i think it was some of both causing the trouble....
Old 05-31-2010 | 07:19 AM
That's awesome.... Fun times ahead now.
Old 05-31-2010 | 07:39 AM
wanna race???
Old 05-31-2010 | 07:41 AM
ORIGINAL: lez1troubles
wanna race???
HAHAHAHA, If I lived in belgium? Absolutely!
Old 05-31-2010 | 08:00 AM
If ever you get the chance to come here,do it, if ever I get the chance to come to the states you've got yourself a race.
