ORIGINAL: hasek1616
ok i also heard that at a certain number of amps or volts or something along those lines that deans plugs become ineffective and bullet connectors become the best choice, is that true?
Deans are good and can actually handle a good amount of amps, but being most batteries from HC come with bullits you are better off getting some extra 5.5mm and changing things over
they are easy to solder and can handle more amps and run cooler
there are lots of videos on youtube with very fast Monster Trucks running some fast mph numbers using deans, so they do work
