RE: This is Bad Right?
It was extablished many years ago that actually boiling in the antifreeze is likely to cause discoloration.
You are supposed to use a 50.50 mix and just keep it around 150 to 170 degrees F and no higher.
I use a pot pourri pot and it never boils the solution. My wife's crockpots will both eventually boil her stew on the lowest setting
