Flyn' the H9 Funtana Set up's and Mods
jmiracle: On the cracking, if the plane is sitting upright, the cracks are beginning to appear from the firewall back to the cockpit. When inverted, it is from the firewall on the underneath the fuel tank and running along the bottom (top if it is right side up) back to the cockpit area. To get to the front, you would need to remove the tank and any foam that might be underneath. In the rest, it is already exposed from the throttle servo forward to the bulkhead where the wing dowels are inserted. I am considering using a brush and brushing on 5 min epoxy. I know this will add weight, but I am not sure what else to do. I will also strenghten the dowels and bulkhead area around the tank for the dowels.
Just for the record, even if I can't get this plane to do everything, I still am impressed what it offers for the size and weight.
