RCU Forums - View Single Post - I need some help
Old 06-01-2010 | 12:04 PM
milsurp53
Default RE: I need some help
If you over voltaged the board, it could be bad. Anything is possible. Is the transmitter light on? Is the antenna screwed in tight on the Tx? Is the antenna connection good in the tank, both the plug and the screw to the external antenna? Is the external tank antenna on?
