RCU Forums - View Single Post - ASP/MAGNUM FS400AR Rebuild/Overhaul
Old 06-03-2010 | 08:49 AM
  #201
Primi
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Congratulation Kmot,
you did a excellent job on this engine, I always followed your build and learned a lot. Especially how you made the exhaust for your engine. I like to make also one for my nine cylinder Seidel the problem I have is how you seal the connection between exhaust bent and the ring, as it looks you only plugged the bends into the ring, does this not blow oil out on the sites when the engine runs? Alternative I would silver solder the two pieces together could you tell me how you did it and how good it works?
Primi
