RCU Forums - View Single Post - This is Bad Right?
Old 06-04-2010 | 09:15 AM
  #56
captinjohn
Default RE: This is Bad Right?
I worked in a Experimenatl test lab for a very big company. The prototype engines was run many hours & then tore down and checked for wear...and other data. To check a piston for wear it must be cleaned without removing any metal. We soaked the parts in acetone overnite & then used scotchbright pads to easy remove carbon & varnish. Then the task of a lot of precision measuring! Capt,n
