RE: Prop balancing
It does make a difference in the wear on your airframe to balance the props. Also about sanding: If you are removing the sharp trailing edges that cuts the efficiency of the props. And there's not much you can do to make the ends safe. Any prop strike bad enough to cut you with a sharp prop will still cut you with a blunted one. Sanding the leading edge smooth is helpful, but leave the trailing edges and ends sharp.
