RE: Comp ARF Flash update
Hi Guy's
I am installing my P-120. I have approx 3/4" clearance between the end of the thrust tube and the inner pipe inside the bell mouth. The manual calls for 15-18 mm between where the chrome starts on the engine to the front face of the bell mouth. Then that makes 3/4" not enough.
Am I okay with 3/4" clearance? How much clearance are most of you using?
It also looks like I will need to raise the engine mount about 1/8" to center in the thrust tube. Does that sound about what your Jetcats used?
Stan
