RCU Forums - View Single Post - balancing
Thread: balancing
Old 07-23-2003 | 07:48 AM
big max 1935
My Feedback: (9)
Default balancing
Make a paper pattern of both your prop cut outs & compare the two , cut or grind to match. Put your cone & back plate together & put a small file mark at the seam & put on your prop balancer . Drill hole in back-plate on heavy side , use several small holes or slowly enlarge the one. When installing match up the marks so you will be putting in same place every time . Go slow . MAX H.
