RCU Forums - View Single Post - A9 flap control?
Old 06-08-2010 | 05:13 AM
A.T.
Default RE: A9 flap control?
ORIGINAL: chocorrol hi guys, Ijust received my A9 last night and everything seems very cool except for one problem I'm having to set flap control, let's see what the mistake is... Ihave set 2aile+2flap wing, Ihave activated the flap control function, Iset the flap 1 at 100% and 0% and flap 2 at 0% and 100% (this is the only way that both flaps will move to the same direction) then, let's say Iset 10% elevator, but when Imix elevator, it will only move when flaps are on the neutral position, so, when Ideploy flaps, elevator goes to neutral, Ican't find anything about this on the manual, Ialready tried reversing flaps but the same thing, another thing is that when Iset the adjust function switch it actually will adjust the travel on one of the flaps, not the % of mixing between flaps and elevator... any suggestions?
Following are good guides to programming flaps:
Aurora A9 - DLG Set up guide with many screen shots for setting Camber, P.Mixes, Flap Control etc ***
Aurora A9 - Flapperon - Flaps - Set up.
Aurora A9 - Flap (Landing) Mix <font size="1">see also sailplane below</font>
<span style="font-size: smaller">and more at
Aurora A9, Spectra Pro &amp; Optima - FAQ &amp; Undocumented Features - Mixes, Setups, Tips. {Individual Links often updated}</span>
Regards
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links
