Since my current controller does not have a proportional brake setup, I use an idle to create more drag on downlines. I think a windmilling prop creates more drag than a stopped prop.
Yes, but on a downline the propeller would not stop if you just turned the motor "off", unless you used a fixed brake. It would still windmill as long as the plane has a reasonable forward speed.
Magne
