RE: BVM Bobcat advice required please
The stock engine mounts that came with the kit will give you the correct down thrust. The wifes composite BobCat flys with a 24# thrust engine and the orginal mount works out correctly. As already stated there should be a small hole in the bottom of the boom that is the starting cg location with out fuel. This is a safe point to start from.
Steven
