RCU Forums - View Single Post - Sky Surfer! RTF Brushed version question
Old 06-09-2010 | 07:39 PM
Banana Hobby Customer Service
Default RE: Sky Surfer! RTF Brushed version question
ORIGINAL: FlooredCOBRA
Hey guys I just recently purchased a Blitz RC Sky Surfer for my son for his birthday. There were a few problems with it but I managed to fix them all except one. This version has the brushed motor and ESC. Normally setting up would be no issue on my 9303 but the radio it came with is 2.4 bare bones. All servos are set and are fine.
The problem I am having is when I push the button to activate the esc and motor it begins to spin at low RPM. I have the trim all the way at the bottom and it is not enough to stop the motor. Normally I would adjust through the radio but seeing this radio is bar bones and only has servo reverse what options are there? Is there any way to bind again and maybe set it to zero? I am stumped on this one and have no clue on how to adjust this. Any help or suggestions would be great guys. Hopefully some have seen this and found a way to correct.
Thanks!
Hello!
I am sorry to hear that you are having trouble with your Sky Surfer. Please be sure that both the throttle stick and the throttle trim are in the lowest down position before turning on anything. Then turn on the transmitter first, then plug in the battery. Your motor should not be spinning until you throttle up or increase the throttle trim at that point. If the motor is still spinning, it is possible that the ESC maybe defective. If that is the case, please email me at [email protected] or PM me with your order information and I will have a replacement shipped right away! Additionally, here is a very helpful link regarding the Sky Surfer and its many, many owners:
<a href="http://www.rcgroups.com/forums/showthread.php?t=1231310">http://www.rcgroups.com/forums/showthread.php?t=1231310
</a>
Thank you,
Saralyn C.
Banana Hobby
<br type="_moz" />
