Yes 8 mins would be about right
Remember More Power = More Fuel !!!
I have a Old OS 60 Vintage goldhead in a Jensen Ugly stick it Sucks 16oz of fuel in about 12 Mins Flat out !!! It is not all that powerfull an engine but has enough for the Ugly Stick , older engines are also less Efficent
Also Using a Tuned pipe will also use more Fuel same thing More Power = More Fuel
Putting the restrictor in the carb will just reduce the power, It would be simpler to trim the throttle on the radio so you have a bit less than full power this
would acheve the same result and if you want you could set a switch on most computer radios to override the trim for extra POWER
If the engine is running nice leave the 7D alone.
Johnkpap
