RCU Forums - View Single Post - Ys91ac ?
Thread: Ys91ac ?
Old 07-22-2003 | 01:44 AM
blue62's Avatar
blue62
Default idle problem
sounds like you might have a leak around the base of the carb...does it have an o-ring around the bottom? check for leaks with wd 40 or some other type of spray oil if it is leaking it will slow down for a second then speed up again
good luck
