RE: engine problem
Lots of good suggestions so far. With a clear line you should be able to what is going on, it may siphon either back to the tank or into the carb thus giving you a flooded engine. Another issue is your glow driver (?), the pocket battery aids are just aids and do not supply enough power to start an engine once it is on the rich side.
