engine mod ?
The main problem with removing metal inside the engine (except the top of the port in the sleeve) is you will increase the volume of the case and lose way more RPM than you would gain by "cleaning up the ports".
I have ruined beyond repair two engines from port work. Both of these was from removing metal in the port/sleeve. Just stick with timing changes and you will be better off IMHO.
