RE: Ignition Interference...Help
Using the correct spark plug? Should it have a resistor plug and does not? Brillelli used CH ignitions for awhile and later switched to RC Exl. Know what you engine and ignition requires for spark plugs and verify that the plug cap is correctly attached. If your ignition has a separate ground wire, try another ground location. The top cylinder fin usually works the best.
