RCU Forums - View Single Post - JetCat P-80 outer shell dent
Old 06-16-2010 | 10:20 PM
Guillermo Ibanez's Avatar
Guillermo Ibanez
Default RE: JetCat P-80 outer shell dent
<div style="background-color: rgb(255, 255, 255); padding-top: 5px; padding-right: 5px; padding-bottom: 5px; padding-left: 5px; margin-top: 0px; margin-right: 0px; margin-bottom: 0px; margin-left: 0px; font-family: Arial, Verdana, sans-serif; font-size: 12px; ">Well, Jet Cat said that this was a pretty bad dent and they were concern about EGV alignment.
They suggested to send the turbine to them.
But finnaly I decided to take the can out and bang the dent out.
Then I reassembled the can again and now all is OK. Even there is no rubbing between turbine wheel and EGV.
Just need to do some tests and if all is OK, fine. If not, I will send it to Jet Cat.
Here are some pictures<br type="_moz" /></div>Question: Why my P-80 has only 6 injectors? I have seen some turbines with 12 injectors. Or 12 injectors are for a P-120?
ID:	1454182   Click image for larger version
ID:	1454183   Click image for larger version
ID:	1454184   Click image for larger version
ID:	1454185   Click image for larger version
ID:	1454186   Click image for larger version
ID:	1454187   Click image for larger version
ID:	1454188   Click image for larger version
