ORIGINAL: Laird SS
Make sure your flux is the correct one for the type of solder you are using. You shouldn't need a mapp gas torch. Ordinary propane produces more than enough heat for the soldering you are doing.
You are correct! That's why I have in the post 'or similar'. MAPP is what I have on hand.
