RCU Forums - View Single Post - soldering
Thread: soldering
Old 06-18-2010 | 02:23 PM
jaka
Default RE: soldering
Hi!
As has been said earlier...Use "Stay Brite" silver solder!!!
This sweet solder is much much easier to use than any other sweet solder. It's also much stronger.
Using ordinary tin/lead solder is also very easy but you must clean (sand) the surface first and then apply flux and then heat again and pre solder the surface. With Stay Brite nothing of this is necessary!
