Toledo Special Motor Mounts
Has anyone had problems with the motor mounts that come with the Toledo Special ARF. Mine have a bend in the section that the motor mounts to. By tightening down the motor to them, it causes the mounts to twist a hair and change the angle of the motor. Also the cowl does not line up to well if I use the pre drilled mounting holes. Horizon Hobby sent me two new mounts and they are also bent. Any suggestions would be appreciated.
Mike</p>
