Toledo Special Motor Mounts
Has anyone had problems with the motor mounts that come with the Toledo Special ARF. Mine have a bend in the section that the motor mounts to. By tightening down the motor to them, it causes the mounts to twist a hair and change the angle of the motor. Also the cowl does not line up to well if I use the pre drilled mounting holes. Horizon Hobby sent me two new mounts and they are also bent. Any suggestions would be appreciated.
Mike</p>
I did not have any prob with the motor mounts in the ARF. You are right about the predrilled holes in the cowl...that is not a great idea. I had to lengthen/enlarge the holes to make the cowl fit properly. It would have been wiser to let the builder determine the hole locations after mounting the engine. Jon
<div style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none">I just looked in the instructions and noticed that Hangar 9 is using a Satio 82 with an old style engine. I have to look into if the specs. are different from the old to new style case. I beleive that the Satio 72 and 82 share the same case but i will have to verify that as well.
If anyone has any info, please chime in. Would Matt Adrain happen to have any info? Thanks
Mike
Read more: <font color="#003399">http://www.rcuniverse.com/forum/m_8689208/mpage_2/key_/tm.htm#ixzz0rOVW5vyp</font>
</div>
Mike
</div>
