RCU Forums - View Single Post - ASP/MAGNUM FS400AR Rebuild/Overhaul
Old 06-20-2010 | 10:05 AM
  #221
Kmot's Avatar
Kmot
My Feedback: (24)
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
ORIGINAL: Dad_Roman
You see that??? Gots his own compression gauge for glow motors
Whats the compression run on your motor and some others in general?
You can have one too!
https://myatomic.com/catalog/viewsku..._gauge_0-60psi
Well, so far the compression readings are 54 psi to 60 psi on this ASP radial.
I am going to buy the Dynamite gauge as well since it goes to 160 psi.
http://www.rcplanet.com/Dynamite_Com..._p/dyn2514.htm
