RCU Forums - View Single Post - Ryobi Conrod failure
Old 06-23-2010 | 01:23 PM
av8tor1977's Avatar
av8tor1977
Default RE: Ryobi Conrod failure
I'm not sure how someone can say the conversion engines "aren't worth the time or money". I have a Ryobi in my big 76" Tiger Moth biplane. It was given to me, and you can often find them for free or a few bucks at yard sales, swap meets, small engine shops, etc. It took me about an hour to convert the engine. I also put a Frank Bowman ring in it, raised the exhaust timing to 150 degrees, made a free flowing muffler, and added electronic ignition. It turns an 18 x 6 prop at around 8500 rpms and hauls the big Moth around just great. Level flight loops, Immelman turns, etc., and flies around at less than half throttle except when I am doing aerobatics. Total investment with the ring and ignition system = 80 bucks.
My brother has a very nearly stock Ryobi on his 15 lb. 80 inch wingspan Ryan's Rebel. It turns an 18 x 6 prop at around 7700 rpms and hauls the Rebel around just fine. Will loop from level flight at just over half throttle.
How can they not be worth using????
AV8TOR
ID:	1457418   Click image for larger version
ID:	1457419   Click image for larger version
