RE: RAM500, different pump, help
Hey Guys, Thanks for the info, i dismateled the turbine blew out the lines and guess what i got full throttle (156K) so i think i got it figured also blew out a plug, just so i know if i did this right after i removed the front housing with the starter on it i removed the front plate and there was 3 small lines that are there 1 gas 2 fuel these are the lines i blew out cleaned off the fittings and put everthing back is this right?? Just want to make sure.
Thanks Again for all your Help
Pat
Lasercut USA
