ORIGINAL: alport78
ORIGINAL: jmaxey51
now when putting the diffs in make sure to use 2 shims on the ones that cross inside the diff on each gear.
Sorry but my english is not well. I can't understand the part above. I know how to shim diffs but I assume you mentioned to put shims somewhere else instead in the diff case and coludn't understand where.
sorry for the confusion, but i just looked in the owners manual and it tells/shows you how in there, for some reason i thought they left that parts out.
