RCU Forums - View Single Post - nexstar ep select rtf battery charger
Old 06-27-2010 | 10:10 AM
CGRetired's Avatar
CGRetired
Default RE: nexstar ep select rtf battery charger
ORIGINAL: redcasey55
Thanks CG...Unfortunately the charger I have, the alligator clips cannot be removed. I have found a few power supply sources after some research last night that I can plug into an a/c outlet and they switch to d/c. I will probably have to choose one of these. Integy and Realplanes are two that I think I will go with. Thanks for your reply...appreciated.
Red
Ummm... can't be removed? Not even with wire cutters? Maybe I don't quite understand what you are working with here.. post a picture or a link to your charger so we can get a look at it.
CGr.
