RCU Forums - View Single Post - Prop reamer~do I need one?
Old 06-27-2010 | 02:33 PM
bigtim
My Feedback: (13)
Default RE: Prop reamer~do I need one?
I have a reamer its handy but not necessary, if you have a drill press then you could drill the hole closer to the exact dia. of the engine shaft, using a regular drill is a crap shoot its really easy to oval out the hole and the prop is done.
I am not overly nutty about checking balance,some guys are real OCD about it, but after opening up the hole its a good idea to check the prop balance,the larger the prop the more it makes a difference, just to make sure its not way out of tru
