RCU Forums - View Single Post - Found PAW 06
Thread: Found PAW 06
Old 06-27-2010 | 04:20 PM
AMB
Default RE: Found PAW 06
Hobbsy the lightnin bug will get the sure start Cox 2 pcs 1/4 sq glued to the firewall longwise will take care of the offset required for the choke tube clearance then its a bolt up
with 4 screws will plenty of room for a small 2 oz tank behind the wall then on with the flying surfaces ,servos are already in. The tigermoth with the cabines and fus support for the upper wing will take some work plus the detail work, paint the cowl, install windscreen, landing gear, back to the lightnin bug the cox surestart easily hand starts, and really screams will hold the front intake bee 049 for a hotter plane martin
