RE: Aeromarine cat 18
Interesting, you may run into some trouble using that strut on anything except a JAE as it has no adjustment and what little you can adjust it with shims or slotting may not be quite enough also the flat bottom it has will act like a lifting surface, might think on that to. What was wrong with the strut it had-the hardware on the rtr mean machine is decent stuff..
