RCU Forums - View Single Post - nexstar ep select rtf battery charger
Old 06-28-2010 | 11:39 AM
redcasey55
Default RE: nexstar ep select rtf battery charger
Hey Chevypower,
thanks for the response. Yeah the nexstar had 2 defects the plastic that holds the wings together was warped on the side where you had to join the wing. you could see the difference where it was joined to the other. Also the wing that I couldn't connect was missing the blue stripe on the bottom that goes all around the wing top and bottom on the other. I think that this particular nexstar may have been someone elses return.
Anyway, I will be getting another soon. I can't wait to take it up. Willbbuddy up with an instructor initially. And will be using the realflight simulator of the nexstar.
Thanks again
Red
