RCU Forums - View Single Post - Performance Specialties/YS
Old 06-28-2010 | 09:14 PM
dhal22
Default RE: Performance Specialties/YS
ORIGINAL: flywilly
YS 61AR and the 'ABC' version of the Hanno special (MKI or MKII)
I believe you could put the AR version in the earlier Longstroke, but I'd check the porting in the case to make sure, of course a little work with a Dremel tool would work, too
FYI - the stock YS piston/sleeve is listed as AAC, however the 'C' is not chrome, but does last longer than the Nickasil used by OS. If you have a new OS/YS and a new replacement piston/sleeve from Performance Specialties or me (both built by Henry Nelson) then I'd replace the stock with the Nelson parts and save the originals for a rebuild later (maybe never) or to rebuild another engine. The stock OS liner typically lasts 300-500 flights (sometimes longer if the engine isn't run too hard) before performance degrades due to 'peeling'.
-Flywilly
thx, i thought is was the AR engine i bought the set for.
